Running Matlab with Labview
I'm having difficulty running Matlab with labview
when Matlab is a networked version
(3,022 Views)
Hi qwik,
Essentially, there are 3 main suggestions:
    1. If using LabVIEW 6.0x or earlier with Matlab 6.1 or 6.5, download the updated ActiveX ID attached in the above KB.
    1. LabVIEW uses ActiveX to communicate with the Matlab script server and this ActiveX component is not registered until Matlab is opened. Therefore, try opening up Matlab on the computer before trying to use any Matlab component in LabVIEW.
    1. If the Matlab Web Server in Matlab 6.5 is installed, uninstall this
      feature.
Hope this helps!
Kileen C.
(3,022 Views)
