geting error when build installer
I'm getting Error 33 and dotnet x86 ni language pack error and build stops
how can I solve this issue?
Building executable is fine, but the problem occurs during building installer.
Please advice
regards
Pierre Tannoury
Pevatech International S.A.R.L
(3,276 Views)
Hi Pierre,
I have found a similar case that was resolved by the following:
1 Go to the directory, default is "C: \ Program Files \ National Instruments \ Shared \ MDF \ Manifests \ '
2 Find "NI .NET Framework 2.0 Language Pack x86 Installer {F8ECD2D6-659C-49EB-8454-5F8F7B526FCF} .xml".
3 Make a copy and change the name and store it on the desktop.
3 Delete the original file.
4 Try to create a installer again.
5 If the problem is not resolved, restore your backed up files into the original location.
Daniel Fulop
Dániel Fülöp
Field Application Engineer (CLA, CTA)
(3,262 Views)
thanks for helping,
i still receive another messages but the dotnet error message is gone
please see below the building status and what's errors remaining
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_Build.vi >> NI_MDF.lvlib:MDFBuildDist_Build.vi
Loading product deployment information
Adding files to installer
Done adding files
Preparing to build deployment
Copying products from distributions
Building deployment
Copying setup files
Setting merged database information
Setting product information
Setting developer part information
Starting final build
Validating...
Copying files...
Updating files...
*** Error: Fatal runtime error. (Error code -10)
*** Error Details:
Access violation! Structured exception code 3221225477
*** End Error Report
*** Error: An internal tool or library returned an error. (Error code -21)
Error Messages
*** Error Details:
Error in MDF API function: _MDFBuildDist_Build
Error List
.\InputParser.cpp(819): IInstallerError 108
Problem with updating Part DataSocket64.msi.
Done building deployment
(3,251 Views)
Hi Pierre,
Please see the following document if it can help you with the "Error 10" problem:
http://digital.ni.com/public.nsf/allkb/53184CA872DFDBE3862577940079C2E6?OpenDocument
Daniel Fulop
Dániel Fülöp
(3,236 Views)
Dear Daniel,
i'm facing same problem even after updating my labview 8.6.1 to 8.6.1 f1 and i do also install the device drivers Feb-2011 and i tried also after installing installerBuilderPatch2010.zip, but installer builder inform me that no need to change any.
i'm still facing same problem and same messages, i'm already keeping external hard drive where the source installation of NI products are available.
please advice
thanks in advance
regards
Peter
(3,227 Views)
Dear Daniel,
I found where the problem,
I stopped the additional installers and I build installer and it works and then I start recheck one by one and I found that the NI Datasocket 4.7.1 making this problem, the source is locally and located inside the Program files\national Instruments\shared\productCache\NI DataSocket 4.7.1.
I need to have this package included inside the installer, so how can I solve it completely without excluding this package?
Thanks in advance
regards
Peter
(3,223 Views)
