get number of bits in integer without converting to string first
Is there a way to do this without converting to a string first to use the string length function? I feel this would be inefficient because type cast makes a data copy (but maybe I'm splitting hairs). I don't want to convert to boolean array and use array size either (inefficient). This is running in a tight loop on RT and that's why I'm concerned. I am trying to preinitialize an array with an index for each bit, and if for some reason I change my code from 16 to 32 bit integers, I don't want to have to go change everywhere I used a constant of 16.
Message 1 of 13
(3,867 Views)
I know it might start a flame war but whats wrong with a Global?
"Should be" isn't "Is" -Jay
Message 2 of 13
(3,858 Views)
Actually, I considered this! No flames from me. The only drawback here is it still needs to be updated, not calculated programmatically. Although the update would only be in one place, it's still nice if it can be calculated in code, making a transition seemless. I'm not against it, I'm just looking for different possible solutions for my own knowledge more than anything. The chance of thi changing in this specific project is slim to none.
Message 3 of 13
(3,848 Views)
Smiley SurprisedJeff is suggesting a global variable?
Actually, I'm in complete agreement.  A global variable that is read only is a very simple, effective, efficient (even processing), and race condition free way to set constants that could change on you.
Message 4 of 13
(3,846 Views)
Why is the "calculation" done inside of the loop?  Can you do it before the loop starts?  I don't know your code, so it could very well be that there is nothing outside of the loop loop that could tell you the data type.
Message 5 of 13
(3,842 Views)
It is in the loop because it can change based on how many milliseconds of data I'm reading. depending on the test I'm running. In standard operation I read 10 ms of 48 I16s of buffered data (480 elements) which results in an array of 7680 (480*16). Certain other tests I just grab a snippet of 2 ms of data, so now the array is 96*16.
I suppose I could make it loop invariant code by caculating the max possible array size for any situation outside the loop, then trim it down accordingly.
Message 6 of 13
(3,830 Views)
You can probably use this to set your Global
DRAT
I mean
Message 7 of 13
(3,813 Views)
DRAT
I mean
One problem with that option is that it uses scripting.  Therefore it can only be used in the development environment.
Message 8 of 13
(3,782 Views)
Tim,
Its read only in runtime.  Reading is all thats neededSmiley Very Happy
I assume Greg can create the case structure to convert rep to number of bits and write to a Global Variable.  (without Rube-Goldberging it TOO much):smileyvery-happy:
Message 9 of 13
(3,772 Views)
@JÞB wrote:
Tim,
Ok.  The blueish property node got to me.  I see now that it is read-only during the run-time.
Message 10 of 13
(3,738 Views)
