get image to ring control from file path
hi,
I have picture ring control. I want to display picture in this ring depending on condition.There are 30+  pictures. Can i call picture at run time? I dont want to put them all in picture ring .
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 1 of 14
(4,000 Views)
You can read & upload the Picture ring (like test ring) with pictures from a folder at run-time.
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 14
(3,995 Views)
Thank you for reply.
Can you elaborate how to do that please?
Gaurav k
CLD Certified !!!!!
Message 3 of 14
(3,979 Views)
Hi Gaurav,
Read the picture files from the folder itself by reading the folder contents using List Folder primitive in the File I/O pallette. Then, pass this list to the Items of the picture ring using a property node.
Message Edited by parthabe on 08-03-2009 07:13 AM
Message 4 of 14
(3,975 Views)
Hi partabe,
I used function that you mentioned..."List folder"  it returns array of file names.But which property node of picture ring should be used? I cant find out.Please answer this too....
Thank youSmiley Happy
Gaurav k
CLD Certified !!!!!
Message 5 of 14
(3,957 Views)
parthabe wrote:
Hi Gaurav,
I have been hunting for that property since LV 6 and I still can't find it. You aren't possibly using scripting are you?
Ben
Message 6 of 14
(3,948 Views)
I found this on NI site...Very interesting solution. Check this link
http://decible.ni.com/content/docs/DOC-2270
Gaurav k
CLD Certified !!!!!
Message 7 of 14
(3,932 Views)
Ben wrote:
parthabe wrote:
Hi Gaurav,
Ben
I apologise sincerely...
I normally include the words, " I think... ", if I m NOT so sure of the answer. I missed it this time. Smiley Sad
It should have been, "Then, pass this list to the Items of the picture ring using a property node, I think..."
Message 8 of 14
(3,916 Views)
Well lacking the property that both parthabe and myself feel should be there...
The animation can be done using a picture control.
Ben
Message 9 of 14
(3,906 Views)
Ben, since the pictures are treated as Str in their utmost depth by LV, is it not easy for NI to make/give this property as extra (only) for the Picture Ring as "Items"... ?!
Message 10 of 14
(3,904 Views)
