get .doc report generation working in build, does work in LV
Just a couple of things you could try:
You use the path method in two places, I hope you have corrected them both.
Try using a path constant instead of deriving a path just to be sure (for debugging purposes).
Create a very simple report generator as a separate project and try building it, also post it if you can.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 11 of 14
(709 Views)
I can do simple report generation, there seems to go something wrong at opening a excisting word document.
Message 12 of 14
(707 Views)
Patrick,
When you are building the application, make sure you add all the support files you added to always included as below:
Also make sure that these files go to the support directory and not part of the application itself, as below:
Hope this works for you, please report back if you are getting any errors.
regards,
aCe
Message 13 of 14
(701 Views)
A colleague made an change for me and now it is working:
See screenshot how he modified NI_report.lvclass, now the error is gone and everything is working fine
Message 14 of 14
(699 Views)
