generating a signal with T = 25 ms
I am on the host a periodic signal and sending to the target through a FIFO,
I can visualize on an oscilloscope the correct signal, but I want to generate it with a period of 20 ms and not on 10micro s
Are there any changes to make or functions to add?
Thank you
(2,660 Views)
You want to run an instrument designed for MHz frequencies at 50 Hz?  Maybe you should buy a USB-6009 or equivalent, which isn't that expensive and works in the KHz range.
(2,612 Views)
I just want to configure the signal generation (it's a noise) to have a period of 20ms, to be sync with the sector (50 hz)
(2,610 Views)
I have to admit I have no idea what you just said.
Bill
CLD
(Mid-Level minion.)
(2,586 Views)
