generate two different number
how can i generate two different number?The first must be always bigger than the second.
Message 1 of 19
(5,828 Views)
You may need to tell us what constraints apply to the first number. After generating the first number, use Increment to add 1 to it to produce the second number.
Lynn
Message 2 of 19
(5,823 Views)
Of course, Lynn meant "decrement" to make the second number smaller than the first, which makes the first bigger than the second ...
BS
Message 3 of 19
(5,814 Views)
Yes.  I should read the posts more carefully.
Lynn
Message 4 of 19
(5,807 Views)
Homework?
Message 5 of 19
(5,806 Views)
Here you go.
Message 6 of 19
(5,800 Views)
Thx
Yes it's homework .i have to do operations with two random numbers.And the value cant be negative
Message 7 of 19
(5,787 Views)
sorry.I dont really understand what you say.i think i expressed myself wrong.So i have to generate two different random number.and the value cant be negative.So the first number must be always bigger than the second.
sorry but we started to learn labview few weeks ago
Message 8 of 19
(5,771 Views)
What have you done? You have the random number generator on the palette and were given one solution.
Message 9 of 19
(5,758 Views)
Accepted by szabolcs1295
Only itegers or also fractional/decimal numbers?  Any real range of values you can use?
I would just generate two numbers (based on whatever parameters you may have) and then use Max & Min to sort them.
Message 10 of 19
(5,754 Views)
