generate new interface and camera
i have installed niimaq 251. How do i create a camera that meets my specs?. the ones i see, the fields are
grayed out and can not be modified. How can i enable grayed out fields in the camera file?....
My camera is parallel interface and uses 12 bits. I can not change these in the camera files i open.
Habib
(2,612 Views)
Habib,
If you can not find a camera file for your camera that ships with the IMAQ driver, try looking at out camera advisor for any support we may provide for the camera:
http://sine.ni.com/apps/we/nipc.specs?action=search&asid=1102
This will incude Camera Files, Support Files, Cabling etc...
If you are unable to locate the file for your camera, we typically will attempt to create one in house. You will need to fill out the attached questionnaire and return it to support@ni.com (IMAQ/Motion). We will also need the timing diagrams, pinouts and any other instructional information from the camera. It is also benefical if you can send in the camera so we can verify the file works properly. Once our engineers have more info ont eh camera they can give you a time
line for completion.
I hope this helps!
Best Regards,
Chris D.
NI Applications Engineer
(2,612 Views)
