generate a unique number from two numbers
hi
i need to generate a unique number from two given numbers.wat operations do i perform on the two input numbers?
(4,154 Views)
Are the inputs integers or floating point ?
Does the generated number need to be integer or floating point ?
(4,152 Views)
one input is an integer and the other is floating point.both are positive.the genrated number has to be unique irrespective of its format
Message Edited by psychic on 04-20-2005 04:02 AM
(4,144 Views)
OK, I think you will have to append the numbers to get a unique number, but to demand that this unique number is independent of the format of the two original numbers is a bit awkward. In order to append the two numbers and have them unique independently of original format, you can convert the numbers into boolean arrays, pad to 128 elements (128 bit array will allow for all numbers to be included, up to EXT) and then append them.
The problem is only that you won't really be able to convert back to any number which you can then display in LabVIEW. You could of course convert back to an aray of U32, but I don't think the series of displayed numbers will really be very intuitive.
The whole problem would be much easier if you could fix the format of the numbers to be combined......
Hope this helps
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(4,126 Views)
Hi psychic
If you are looking to create a single number then a double (8 bytes) is the only real option.
You will be limited to a Single (4 byte) floating point and a 32 bit (4 byte) integer. You can then concatenate these two values to produce a unique double. See the attached example.
Hope that helps.
Neil
(4,126 Views)
hey thanks a lot neil..ur vi works perfect
(4,120 Views)
