generate RFSG two tone
HI all.
Is there any body can help me to know how to generate RFSG two tone using arbitrary waveform. I have found an example bulti in NI examples. It uses arbitrary spacing and uniform spacing.
What I am trying to do is how to generate two tone with different power and frequency? becasue in NI example they uses fixed spacing between freq. and I want to control the frequency input instead of using frequency spacing? any support? Thanks in advance
Regards
(3,489 Views)
Hi Al-Rawachy,
This question seems very similar to another question you have posted here:
http://forums.ni.com/t5/RF-Measurement-Devices/Generate-two-tone-with-freq-sweep/m-p/3306983
I think it would be better to keep the discussion to one thread, as a lot of points will be similar. The other thread already has a post that could solve the issue.
If I am incorrect and these questions are not similar, could you please describe the differences between the questions and what you are trying to achieve in a bit more detail?
Kind Regards,
Hakon,
Applications Engineer,
National Instruments, UK
(3,418 Views)
