‎08-19-2021 07:37 AM
So in this case, why can't the result be displayed because the input from the sensor is still an error and the fuzzy rule has an error? is that right sir?
‎08-19-2021 08:30 AM
The VI itself works.
What i'm saying is that you either have wrong inputs to the system or badly designed system.
Your input 1 accepts range of values from 0 to 50 ... the value you are feeding it is -127 ---> out of range
Your input 2 accepts range of values from 0 to 14, you are inserting 15.45 ---> out of range
Your input 3 accepts range of values from 0 to 70, your value is 68.05 BUT there is no rule covering these values so the output is 0.
You have 3 inputs, each made from 3 membership functions, but only 9 rules. You need 27 rules to cover all the possibilities.
----> NO rule covering these 3 values, even though they are all in range
----> all values are in range and a rule covers them, so output is not 0
Again, use Test System feature of Fuzzy System Designer to check how your values interact with system and then either change the system or fix arduino so it outputs proper values.
‎08-19-2021 08:41 AM
now I understand what is the source of the problem, thank you for the help it really helped me sir
