TB-2605 configuration
I work with NI TB-2503 modules on which the TB-2605 module is connected.
On NI-max you can configure the TB-2605 on the TB-2503. I need to use it in 4 wires mode and I could do it until recently, but it seems that there has been an update and I can only choose, in 4 wires mode, the configuration: 12*1 Mux.
I can't read the values of my temperature sensor in this mode. Has anyone encountered the same difficulties? Is it possible to understand how to adapt to this change?
Best regards.
(1,239 Views)
Have you checked the pinouts?
In this article, the correct architecture is described, maybe there is something you've missed.
Thx.
(1,104 Views)
