functionality on the graph
Hi, Hello, I am developing data acquisition code on labview and I would like to add functionality, I display my data (2 parameters) on a single graph; I want to display the min, max and average of each parameter, I tried with propery node but it only displays the max and min of one of the data (the most important)? how can I fix this
and the second question, could I use code to change the scale of my graph so that, if necessary, I could have more detail on the graph?
thanks in advance
Message 1 of 10
(1,988 Views)
Accepted by ameletudiante99
Hi amel,
By writing "working code according to the requirements".
Yes.
General suggestion: when we should discuss problems in your code then you should attach this code…
Message 2 of 10
(1,976 Views)
hi
Here is my code,
I don't understand what you mean by  By writing "working code according to the requirements".
can you please  point me in the right direction, I have no idea how to do this?this?
Message 3 of 10
(1,957 Views)
Hi amel,
when using recent LabVIEW versions you should downconvert your VI before attaching. (File->Save for previous)
Most say "for LV2021 or older", I prefer LV2019.
Message 4 of 10
(1,945 Views)
You can have a routine to find the max, min and average of the data, then plot them together. but depends how your are ploting them, You can plot htem as waveform and as a chart .
Please save your code for labview 2020.
RKO
Message 5 of 10
(1,921 Views)
You have two main choices:
  1. Create additional waveforms with constant values and display them as additional plots
  2. Create horizontal cursors and place them at the min/max/mean, etc. for each plot.
Here's a subVI that would process one waveform to create the others for max,min,mean (case 1), call it for each.:
And here's how you could set the cursors (make sure you define 6 cursors first)
Message 6 of 10
(1,888 Views)
Many years ago I made an XControl that has over/under limit highlighting (it's one of my early XControls, so it's not so polished).  Maybe you can use that as a guide to build something.
Message 7 of 10
(1,873 Views)
thanks in advance
There are properties for auto-scale, min and max of the x and y axis and they can be modified via the relevant property nodes. Of course you should turn off autoscaling when setting defined min and max, else it is futile.
Message 8 of 10
(1,867 Views)
Hi ;
hi, here is the code in the photo, I will no longer have access to my labview software until next week
Thanks a lot
Message 9 of 10
(1,825 Views)
Hi;
thanks I will try
Message 10 of 10
(1,824 Views)
