function generator
hello...i'm izuan..
i want to design function generator two channel but i don't have any idea to built channel...
can u help me..
this is my bloc
Message 1 of 9
(4,596 Views)
There is the Getting Started with NI-DAQmx and the basic LabVIEW tutorial. After that, look at the DAQmx examples that come with LabVIEW. You might also want to learn how to better phrase your question. Explain your problem with a few more details.
Message 2 of 9
(4,565 Views)
I'm design function generator 2 channel but I have problem to connect wire at sampling clock..
Any idea or solution..i need ur help...tq
Message 3 of 9
(4,549 Views)
I don't understand why you are trying to connect it to anything. If you really want to, then make your SampClk.Rate an indicator.
Message 4 of 9
(4,539 Views)
ok,thank you so much...
Message 5 of 9
(4,519 Views)
hye,can u help me..
i test my function generator but have error..i don't to solve this error..
Message 6 of 9
(4,500 Views)
i would search this website for 200524 error code, there is normally good advice on how to solve the error. I searched the discussion forums and found this solution:
http://forums.ni.com/t5/Multifunction-DAQ/Error-200524-in-DAQ-6216/m-p/1703368
hope it helps
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 7 of 9
(4,496 Views)
thank you so much for your information
Message 8 of 9
(4,490 Views)
No problem
Message 9 of 9
(4,485 Views)
