function for summation
I am trying to find a single function that will perform the following function: for a given x, produce the sum of all the integers from 1 to x.
I know factorial will give me the product from 1 to x, but my memory for math functions escapes me on the sum, and it seems I will need the name of the concept before being able to search for the function...
I know of several ways to programmatically perform this, please see attached picture - the upper most branch was the existing code, and the lower two my (supposed) improvements to it. However, I feel that there ought to be one function, or a more elegant programming step, similar to the factorial, which performs all these steps at once, is this true?
Mello
Message Edited by Mellobuck on 04-28-2008 03:29 PM
Data Science Automation
CTA, CLA, CLED
SHAZAM!
Message 1 of 15
(7,133 Views)
I don't feel like working out the whole mathematical proof, but I believe the formula is (0.5x+0.5)X.
___________________
Try to take over the world!
Message 2 of 15
(7,117 Views)
Summation is the correct operation but Labview does not support the mathematical notation as far as I know.  If you'll forgive the crude text format, roughly speaking the equation would be...
n
E(i)
i=1
I think your top vi is the best option, except I'd remove the Build Array primitive.  You don't need it and it will slow things down.
Message 3 of 15
(7,116 Views)
If you put the increment function in line between x and the N terminal of the for loop, you only do the increment once. That should speed things up. The array has a zero element but that does not change the sum. I benchmarked the sum of array elements versus the shift register plus i. The shift register method is about 25% faster.
Lynn
Message 4 of 15
(7,114 Views)
OK, proof by recursion:
1. The operation is correct for x=1.
2. Check correctness for x+1.
  • 1+2...+x=(0.5x+0.5)x
  • 1+2...+x+x+1=(0.5x+0.5+0.5)(x+1)
  • Replace the first part on the left with our equation:
    • (0.5x+0.5)x+x+1=(0.5x+0.5+0.5)(x+1)
    • 0.5xx+1.5x+1=0.5xx+x+0.5x+1
3. The two are equal, so the proof works for x+1 and since it works for x=1, it also works for any other positive integer.
Message Edited by tst on 04-29-2008 12:03 AM
___________________
Message 5 of 15
(7,106 Views)
Ahh, but did you benchmark tst's solution?  My money's on him.  Smiley Very Happy
Assuming you want to sum all integers between 1-100, a more intuitive proof is...
0 + 100 = 100
1 + 99 = 100
2 + 98 = 100
3 + 97 = 100
49 + 51 = 100
The above is simplified as 50 * 100, or 0.5*n*n.  The only number remaining is 50, or 0.5*n.
Therefore, the sum of integers 1-n is equal to 0.5*n*n + 0.5*n, or equivalently, n(0.5n+0.5).
Message Edited by Daklu on 04-28-2008 02:10 PM
Message 6 of 15
(7,105 Views)
Thank you both for the explicit mathematical solutions. I refactored it to:
sum=(x+1)x*0.5
for implementation, but It works quite well. Kudos and 5-stars for you both!
-Mello says math is fun
CTA, CLA, CLED
SHAZAM!
Message 7 of 15
(7,076 Views)
Mellobuck wrote:
I refactored it to:
sum=(x+1)x*0.5
Yes, I realized that's also correct and is much more elegant shortly after I left the computer. It also gives you the added benefit that you can use pure integer math by using Q&R or even bit shifting for performance and a clean diagram.
Another point is that the method I used is obviously called induction, not recursion. Don't know what I was thinking about. That's what you get when you do things in a hurry.
I don't think that can be considered a mathematical proof, since you only show it on a single number. You have to do it with n and show that it's correct.
___________________
Message 8 of 15
(7,031 Views)
Hi Mellobuck,
the formula is the better approach here, but do you see the difference in these two implementations shown in the attachment?
(Infact this was my first thought when I saw your "existing code"...)
Message Edited by GerdW on 04-29-2008 09:44 AM
Message 9 of 15
(7,015 Views)
GerdW,
Oh, absolutely. Don't want to be iterating numbers within a loop if not necessary, although incrementing once before the count(N) terminal (as above) seems even more elegant.
Plus I knew that build array in the loop was useless and an extra visit to the memory manager on each iteration.
Mea culpa: The code with the build array within it was given to me from an older project, but I was the one who left the increment inside the loop in the second, my main aim was to eliminate the array. Thanks again to everyone for the help.
-Mello
CTA, CLA, CLED
SHAZAM!
Message 10 of 15
(6,979 Views)
