enum
Hi all :
I have txt file ,, please see attach file , this file as to see contain some data,, want I want to upload these data to labview … as list shape ( system enum) ,, I build  application but  its doesn't work
how can i do that ,,if any one do this before
thanks
(3,565 Views)
You cannot change the string values of an enum during runtime.  You would want to use a ring control.  That control can modify its string values during runtime.
(3,551 Views)
please see attach file i bulid application ,,
 I Succeed to read as array but I want to convert these data into list box that I choose from it
to run don't forget to change the path
thanks
(3,543 Views)
You need to use the Strings[] property of the Ring control.  Create a ring control on the Front Panel"
Right-click on it and chose Create->Property Node->Strings[].  You'll get an item on the Block Diagram.  Wire your arry to that property node.
Message Edited by Matthew Kelton on 04-30-2008 07:30 AM
(3,533 Views)
thanks alot
(3,518 Views)
