fsk demodulate
Hi !
Is there any function to analyze fsk signal in labview6.1?
(3,234 Views)
I have never done this before, but I found some links on NI's website which can hopefully lead you in the right direction:
How Do I Change The Frequency Output Of My Pulse Train On The Fly?
Frequency Shift Keying (FSK) with ComponentWorks
J.R. Allen
(3,234 Views)
I do not think there is anything out of the box to do this.
How about;
1) Pass signal to two notch filters set for the two key frequecies.
2) Get amplitude of the outputs of both of the above.
3) wire both to a compare function.
With the appropriate timing control, you are there.
Ben
Have you concidered using a modem to convert the FSK?
(3,234 Views)
Even better,
Extract single tone then compare resulting freq value with limits.
Ben
(3,234 Views)
