front panel objects lock
Hi
In my project i try to lock the frontpanel, when i lock the position it looks like whatever i required.
when i run the VI ojects were moved from the locked position.
Hari
Message 1 of 9
(4,874 Views)
How you are locking the front panel position...? Through the VI properties..? can you post the VI that you made?..
Smiley Wink
Message 2 of 9
(4,868 Views)
Hi Anand
By using REORDER icon in the front panel.
Message 3 of 9
(4,863 Views)
Hi Anand
i attached file.
Message 4 of 9
(4,861 Views)
I cant open your VI am using 2009... i cant guess what exactly happens to your VI...  Post a screen shot of your front panel before and after running the VI (Where the objects gets moved from the locke position)...
Smiley Wink
Message 5 of 9
(4,855 Views)
Hi
Message 6 of 9
(4,852 Views)
I cant guess why this happens.. Just give a try... change the windows appearance from Dialog to Default in VI prpoerties... With and without locking...
Or.. some champs will tell you the possible reason...
Smiley Wink
Message 7 of 9
(4,842 Views)
Hi Anand
It works fine with that options, but the graph plot properties changed(plot color not saved).
when ever VI opened the plot color changed to default color.
Message 8 of 9
(4,834 Views)
Accepted by thinnker
After changing the plot color to your selection right click the graph >> Data operation>> make the current value deafult.... Hope this help...
Smiley Wink
Message 9 of 9
(4,829 Views)
