Hai,
Am using a tree control with drag enabled. The user is supposed to drag a element from the tree and drop it in a target (any indicator like numeric etc., with drop enabled). As soon as the drop operation ends the front panel with tree control hangs up and the fp is released after sometime (30 - 40 seconds) sometimes doesnt. The parent vi with tree control is executing the code uninterrupted but with locked front panel.
It seems like the labview filter event (Drag enter and drop) locks the front panel but fails to release it. whats actually happening. wats the way out.
please help me out at the earliest.
With best regards,
JK
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
