front panel entry data save
Dear All:
               I modified the data like the sampling rate from 1000Hz to 100Hz in front panel and save the vi with normal "save" function . It defulted to be 1000Hz when the vi was restarted. What is the proper way to save the entry data in the front panel? Comments will be greatly appreciated!
zibin
(3,050 Views)
Hi zibin,
If you're only concerned about that particular control, you can right-click on it and choose "Make Current Value Default" before saving your VI.  If you want to preserve every value on your front panel, go to the Edit menu and choose "Make Current Values Default" before saving your VI.  With both of these methods, the "new" default value is the one that will be displayed the next time you open the VI.
Hope this helps,
-D
(3,034 Views)
