.NET 2.0 Framework and LV8.0
I see that LV7.1.1 now supports .NET framework 2.0 with the recently released patch.
What are the plans to support 2.0 for LV8.0? According to the release notes, it is currrently only compatible with .NET 1.1.
BTW- The addition of the Class Browser in 8.0 is a nice feature!
Our C# developer is very impressed with the ease that I can expose and work with the properties and methods in his dll's.
(Hi Brianhappy smiley)
(2,683 Views)
Hi there!
Oops - need to take a look at the release notes again...but LV 8 does support .NET 2.0 just as LV 7.1.1f2 does.
And glad to hear that the Class Browser is working out for you. Do let me know if you run across things that you think "boy, if they only did X, using .NET in LV would be a lot easier".
(2,669 Views)
Cool!
Maybe I misinterpreted the upgrade notes- on pg 7 says you need .NET Framework 1.1 SP 1 or later...
I thought that the "later" was referring to the SP level. It made no mention of 2.0 though which IMO it should have.
Glad to read that things went fairly smoothly in the NW
Thanks Again.
-Pete
(2,664 Views)
