frequency to RPM
I need a RPM measurement of a BLDC. I have Hall input signals. I use a cRIO and I program on the FPGA.
So I measure the frequency of one hall input signal using a single timed loop on the FPGA.
In another loop I calculate the rpm from the frequency. This according to the number of poles.
When the motor is running, I can see the number of ticks changing, but the calculated RPM is not changing, it's fixed at 5299,41 RPM.
I hope someone can help me.
(4,767 Views)
Accepted by topic author gihlutax
What is the settings for your Fixed Point data type?  I think you are just hitting the limits of the fixed point settings.  You might need to convert it to a floating point and order to do all of the math.
(4,758 Views)
It was indeed the fxp configuration of on of the data operations that caused the problem. Thank you!
(4,662 Views)
