Can't create labview installer ,need NI System Components from NI TestStand?
I'm creating a labview installer,but it always prompts to ask for NI System Component from TestStand??
I only selected Labview Run-Time as additional installer.And my software has nothing to do with TestStand,although I have TestStand installed.
See pictures.
(4,562 Views)
Is this with any executable or one particular one?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,542 Views)
Sorry,I don't understand your reply.
It happened in make an installer in Labview Project Explorer.I have built the executable file and then use it to make an installer.
With the Labview Runtime engine selected,the installer can be reached.
What was wrong here?
(4,529 Views)
Create a really simple program to do something like add two numbers together, build it into an executable and create an installer using all default settings.
Do you still get the problem?
Mike...
LabVIEW Champion
(4,524 Views)
