fpga
I have to check Hall sensor output. It produces 2.5 volts. But when I connect using FPGA, it shows some raw data 8160. How to get the accurate voltage?
Message 1 of 26
(4,198 Views)
Which FPGA card are you using?  What is the range of the Analog Input?
Message 2 of 26
(4,193 Views)
What hardware are you using?
Some hardware will return a fixed point value that is scaled and some will return the raw A/D counts and you've got to convert that.  The latter sounds like your case.  You need to know the number of bits in your A/D and the input range in order to calculate the voltage per A/D count.
Message 3 of 26
(4,192 Views)
Accepted by topic author gaks
This sounds like the FPGA has a -10..10V input with 16 bits.
The range -32768..32767 (16bits or I16) corresponds to -10..10V.
The value you're getting (8160) corresponds to 2.49V.
Message 4 of 26
(4,183 Views)
You have to get the LSB Weight and Offset Values from the modules and use them to convert the readings into voltages.  See link below.
http://digital.ni.com/public.nsf/allkb/2BDBB541D421673A8625752E005F4B32
Message 5 of 26
(4,169 Views)
i am using pxi-7842R i have connected the output of hall sensor to SCB 68 . i want to convert the RAW data to actual voltage ...
Message 6 of 26
(4,147 Views)
hey this range is correct but...pls tell me how to configure it for my actual voltage output i.e 2.49 v...i am using pxi-7842R
Message 7 of 26
(4,137 Views)
The FPGA does not support floating point numbers (well in LV FPGA 2012 it does support SGL).
To transform a I16 value into -10..10V just divide the I16 value by 3276.75 (multiply by 10 and divide by 32767.5).
Message 8 of 26
(4,122 Views)
actually i m new..i dont know how to perform that action can you explain it please
Message 9 of 26
(4,120 Views)
If you don't know how to perform a simple division I would recommend going through the LabVIEW Tutorials...
Message 10 of 26
(4,118 Views)
