10-10-2012 04:12 AM
Is there a simple way, to "always" get a timestamp in the english language? I live in Holland, and my timestamp gives: 10-OKT-2012 but it should be: 10-OCT-2012. Now i can change the country settings and get the right timestamp, but i don't want, because my software will be installed on several "dutch" PC's...
I can get the month number and hook it up to an array to get the right "english" month, but isn't there an easier way?
Thijs Boeree
Solved! Go to Solution.
10-10-2012 06:32 PM
I think that you will need to create a lookup table as you suggested.
There is a discussion on the LAVA forums about common date formatters that you may want to follow:
http://lavag.org/topic/16221-what-are-the-most-common-date-formatters/page__fromsearch__1
10-11-2012 02:05 AM
I think i have to make a lookup table indeed, i get frustrated sometimes over this 100 millions ways to write a timestamp... But, oh well!
10-11-2012 08:06 AM - edited 10-11-2012 08:08 AM
I certainly agree. Using anything other tha ISO-8601 in my mind is just asking for trouble.
See my signature below for a format string to convert a timestamp to and from a string with no ambiguity (uses zulu or GMT time).
