fpga
I have SbRio 9642 and LabVIEW 2013 , can i compile with Xilinx14.4 compiler ? if not which one is siutable
(3,587 Views)
Hi oldcairo.cairo,
Following the below link, it seams that you can use LabVIEW FPGA Module 2013  with Xilinx Tools 14.4
https://www.ni.com/en/support/documentation/supplemental/17/labview-fpga-module-2013-sp1-xilinx-tool...
Here the drivers compatible with your sbRIO.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/fr/pg/1/sn/ssnav:drv/q/SbRio%209642/
Here the LabVIEW NI-RIO compatibility:
https://www.ni.com/en/support/documentation/compatibility/17/ni-rio-and-labview-version-compatibilit...
You now have everything you need to check your software compatibility.
Good luck.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(3,570 Views)
I don't know all the limitations but NI now has free cloud compile for FPGA if you have a valid SSP.
http://forums.ni.com/t5/LabVIEW/Labview-FPGA-Module-and-Windows-10/m-p/3192418#M924797
Next time I need to compile I'm not going to try to install the several GB of installers, for the various targets, I'm just going to have NI take care of it.
(3,512 Views)
