fpga
Hi.
I am using cRIO 9012 and cRIO 9114 for chassis with LabVIEW 2013.
I got this error while a new FPGA project.
Can anybody tell me what should I do?
Thank You.
Message 1 of 9
(4,357 Views)
Have you given static IP? Give static IP and check. l
i.e cRIO 192.168.0.2 and computer 192.168.0.1.
PBP
Labview 6.1 - 2019
Message 2 of 9
(4,334 Views)
Hi PBP..
@I've tried both..give static IP @ DHCP..
i.e: cRIO 169.254.4.42 and computer 169.254.4.26..
but, still it shows this error.
I've checked in NI max, the connection is all right (connected-running)..
fyi, i've build a fpga project before and there's no problem at all..
but,when i'm trying to build a new fpga project,the error is pop up..
besides that, i can't run my previous fpga project anymore since it shows error-63043.
Message 3 of 9
(4,296 Views)
Can you please attach screen shot of FPGA VI block diagram?
Have recompiled your FPGA VI?
PBP
Labview 6.1 - 2019
Message 4 of 9
(4,280 Views)
Here are the attachements of the screen shot of my FPGA block diagram..
Yes, I've tried to recompile but then it shows error-63043..
Message 5 of 9
(4,268 Views)
Can you put some delays in every loop? How much is your sample rate?
You have not connected delay teminal to wait until... function.
You can also combine voltage and current loop if all have same sampling rate.
PBP
Labview 6.1 - 2019
Message 6 of 9
(4,256 Views)
Hi PBP..
Good news! I've succesfully deployed the VI to the real time target and can build the new fpga project without an error.
I believed it caused by the processor overuse .
so, i decided to uninstall some of the unused software to the controller.
Btw, I thank you very much for your help. Really appreciate that..Smiley Very Happy
Message 7 of 9
(4,245 Views)
Great.
Thanks for kudos....
If you put some delays in loop this will allow processor to do other task. 🙂
PBP
Labview 6.1 - 2019
Message 8 of 9
(4,229 Views)
  • Have a useful title.  The title of your question should never be "labview" for "fpga".  Your title should also not be a paragraph.  It should be a quick summary of the topics your post is going to discuss.
Source
Message 9 of 9
(4,214 Views)
