fpga sampling rate
sorry for my english...
If I do the dacimation from the frequency 0.98 kHz (this is the min frequency NI 9232) and I want to decimate this frequency by 2,4,8, etc.
Should I use low pass filter before this decimation to prevent aliasing ??  You wrote a pre-filter is set up when the sample rate (0,98khz) is choosen.
(I think I should and set different filter parameters according to each decimation rate)
Message 11 of 12
(780 Views)
yes, you are right, you should your own LP filter for that.
And than you will decimate your data.
Ion R.
Message 12 of 12
(778 Views)
