fpga is busy
I am getting this error when i am trying to open a fpga vi reference. I am also not able to run the vi or do anything.
Error -61141 occurred at Open FPGA VI Reference in Initialize_FPGA.vi->Host.vi
Possible reason(s):
LabVIEW FPGA:  Operation could not be performed because the FPGA is busy.  Stop all the activities on the FPGA before requesting this operation.
FPGA activities:
Reference open through FPGA interface.
Any help??
(6,914 Views)
Are you getting this error on the PC (78xx)or a cRIO? Does this error always come or only after running a couple of times. Are you repeatedly opening and closing references?
Amit
(6,905 Views)
After opening the reference, use a reset method before running. It seems to
be running already, which happens e.g. when the fpga has a continuously
running loop.
Wiebe.
(6,901 Views)
If you get this error, set your chassis to FPGA mode in the properties and then redeploy the chassis. You should not have to recompile your code.
Message Edited by mishkin on 04-14-2009 12:20 PM
Misha
(6,789 Views)
Hi I have this error as well. What does it mean to redeploy the chassis. Whats the chassis?
Regards
Simon
(6,204 Views)
I'm using cRIO-9114 and I also have this problem. I think it originated as I had endless loops inside the FPGA and tried to start a FPGA reference but the program crashed. So the reference never got closed and now what ever I do related to the FPGA returns the error that "FPGA is busy".
Trying to add C module, viewing RIO Device Setup or deploying binaries on the chassis return the error.
I didn't find any way of getting rid of the old program running on the FPGA.
(6,141 Views)
I solved my problem by formatting and reinstalling the system through MAX.
(6,115 Views)
