‎10-11-2012 01:19 PM
I need help because I'm not able to install software on my cRIO and I really don't have any idea.
When I try to do "add/remove software" a window with written "The selected target does not support this function" appears.
I tried to format it. So now I have a formatted cRIO, with a blinking status light (2 times per second) and I'm not able to install anything on it.
What should I do?
‎10-11-2012 01:33 PM
What should I do?
Well, the FPGA can not have any ordinary software. You program it with bitfiles from LabVIEW.
Try to do basically the same, but this time click the cRIO controller and select "add/remove".
Br,
/Roger
‎10-11-2012 02:01 PM
Hey Mauro,
I definitely recommend that you start here: http://www.ni.com/gettingstarted/setuphardware/
‎10-12-2012 04:31 AM
Sorry,
it was a mistake on how I named the question.
In the picture you can see the error:
‎10-12-2012 07:18 AM
Perhaps you should try the technical support referring to this post.
Br,
/Roger
‎10-17-2012 03:38 AM
Hi
It could be a problem with the RIO driver, so I would advise you to try out these suggestions
-Repair their current RIO-driver
or
-Upgrade the RIO driver to a newer, compatible version
or
-Remove/unistall the driver and reinstall a new version
You can find the RIO-driver at NI.com/drivers
Espen
AE, National Instuments
