fpga and RT - change rtexe and bit file from FTP
Hi guys,
I hope to be in the right section but I have an issue with mi cRIO 9066, I just want to change via FTP the rtexe that I've created in advance and I'm not able to locate the ni-rt.ini in my target device in order to change the run as startup file. In my cRIO I'm able to find the startup folder with more that one rtexe inside so how can I "select" wich is the file to run as startup on the cRIO? Could someone help me?
Thanks in advance and I'll wait any feedback.
(3,788 Views)
Accepted by FranMe
first of all, you can use WebDav to transfer files to your cRIO-9066 (which runs Linux RT OS).
You can check for the ni-rt.ini file in folder /etc/natinst/share/.
You can also read this and this for programmatic setting of startup application.
Hope this helps!
Bye!
Licia
(3,687 Views)
Thanks Licia for your quick answer...it's what i was searching for.
Thank you very much.
(3,647 Views)
