fpga accelerometer
I was hoping i could get some help i'm using an Accelerometer with cRIO in FPGA mode. I can get the raw value just fine using the NI9234 card. I would like to integrate twice so i can get the displacement from the sensor, I'm using IEPE AC coupling and running on 2mA. I'm not sure what the best apporach is and what can prevent the noise being amplified. What is the best way forward ?
I would like to get this all done in the FPGA.vi as shown below.
Many Thanks
Message 1 of 12
(6,769 Views)
Hi, Guy's
Is it possible to carry out filters and integration on the FPGA side ? I've found others converting the acceleration to displacement on the host side using filters and integral function.
Cheers
Message 2 of 12
(6,732 Views)
yes it is possible and relatively easy.
Stu
Message 3 of 12
(6,717 Views)
Hi, great I'm new to doing this so could you please give me the easy process ? Are you using the sound and vibration package ?
Any help will be much appreicated.
Cheers
Message 4 of 12
(6,698 Views)
to get sensible help I would recommend posting some code so people can see where you have got to - screenshots are not always easy to see, especially large BDs like yours is getting - no one can see all the cases/sequences.
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 5 of 12
(6,694 Views)
Ok, i can post my code which is very simple at the moment.
However there doesn't seem to be an integration function on the FPGA side and that's where i would like to develope it. I'm aware of DMA and the like for the host side but would prefer to get the value done without that 🙂
What does BDs mean ?
Cheers
Message 6 of 12
(6,690 Views)
BDs - Block Diagram(s)
FP - Front Panel
I don't have the FPGA toolkit installed you you will need someone else to help from here I think, but everyone is in a better place to help now!
James
Message 7 of 12
(6,686 Views)
first, collect the data with your existing code and get the data into labview or matlab or your tool of choice.
second. perform the analysis you are thinking of on those data sets until you are satisfied with the result. (using a pt by pt algortihm)
third. translate your resultand code into labview FPGA.
there are filter blocks available in labview and integration is just summing the signal over time.
do not just jump to labVIEW FPGA without doing steps 1 and 2.  if you have already done these steps, post your code.
Stu
Message 8 of 12
(6,677 Views)
In addition to Stu :
to verify your algorythm:  Create analytic signals where you now the results (for example a sine, sweep, ..) and run your signal processing.
Add noise and a small offset. Still happy with your result?
You have to expect noise and offset. So think about a high pass filter(s)
Greetings from Germany
Henrik
LV since v3.1
Message 9 of 12
(6,658 Views)
Thanks everyone,
I've been experimenting all day, it's abit confusing but i'm not giving up !
I will carry on with this tomorrow, hopefully i'll get it working and share my results 🙂
Message 10 of 12
(6,655 Views)
