fpga, Control and Simulation Module
I am trying to implement control by Control and Simulation Module through NI CRIO 9024. The error message pops up when trying the run the RT vi.
Other vis which are not coded by the Control and Simulation Module can work properly. However, when it comes to the Control and Simulation Module, the error message pops up. Is there anything wrong with the installation of the Control and Simulation Module? Please let me know if you have an idea about that. I appreciate your help.
(2,794 Views)
Hi Richard629,
As seen in this Knowledgebase article, you most likely do not have the Control Design and Simulation module installed on the controller. You can use NI Measurement & Automation Explorer to install the Control Design and Simulation module on your controller.
Allison M.
ni.com/support
(2,772 Views)
