[fpga] Co-simulation on Labview 2010
i'm using LV2010 with FPGA module.
Why the option "Execute VI on >> Third-party simulator" is not available on target (7854R)?
I think i've well configured Modelsim6.5c path and i've updated libraries.
(3,014 Views)
Hello mhed,
Are you sure you have configured the LabVIEW module for using Modelsim ?
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
(2,985 Views)
Well you're right, i forgoten to set the simulator correctly.
Now, it's almost work. When i create a simulation export i've the following error :
Error -123206 occurred at an unidentified location
Possible reason(s):
NI-Farm Internal Error: Client received unexpected or bad data from the server.
<b>Complete call chain:</b>
niFpgaCompileFarm_OpenSession.vi
niFpgaSimulate_CallCoregen.vi
niFpgaSimulate_InitializeNiFpgaDirectory.vi
niFpgaSimulate_InitializeDirectories.vi
niFpgaSimulate_Worker.vi
niFpgaGenerateCode_Worker.vi
(2,978 Views)
If you do a local compile, does it make the error disappear ?
(2,973 Views)
well i'm already made a local compilation, here's the proof :
I've tried to repair my installation, but nothing different after this operation
(2,968 Views)
Do you have the possibility to upgrade to a newer version of LabVIEW ?
Other question, have you administration rights on your PC ? If not, could you try compiling from the Admin session ?
(2,954 Views)
