NI-FBUS USB error
I had this device working yesterday but updated the configuator software and now I the USB device cannot connect. I have it connected to an FF Hub as shown in pictures. I have checked the drivers and they all say they are up to date. This device works on other machines and other devices that work don't work on this machine.
(2,181 Views)
           Hello
-          The description for your error is: Code 10 Device Failed to start: Update driver, you may also be able to resolve this issue by removing the device in device manager, and going through the Add New Hardware Wizard.
-          According to that description and because you updated software, something happened with your driver, so you would try to repair it.
           Regards
(2,159 Views)
