formula node
I am very new to labview and i am having an issue with the script for the formula node. How would the following code be written in the formula note.
if (x<=8||x=>20)
y=4 && z=300;
else y=15&&z=600;
(3,343 Views)
Why do you want to use a formula node?  Go with the (data)flow.
(3,330 Views)
Still, if you were gung-ho about using the formula node you would enter it like this:
float y;
float z;
if (x<=8||x>=20)
  y=4;
  z=300;
else
  y=15;
  z=600;
where y and z were output variables of the formula node and x is an inputer variable driven by a front panel numeric control.
Think "C".
Message Edited by smercurio_fc on 02-09-2006 12:56 PM
(3,306 Views)
hi
perfect  smercurio…  ,that is what i need to know.
thank you
(3,291 Views)
