Problems with USB 6008 example
I have a NI USB 6008 with LabVIEW 8 and NI-DAQMX Base Windows Version 1.4 on an XP PC.  I have used the 6008 before with LabVIEW 7.1 with no problems.
In MAX the 6008 (Dev1) works no problem, but when I try to work with the examples from NI-DAQMX 1.4 I get an error message Error -200220. It seems like it does not recognize Dev1. When I start the NI datalogger I get Error -200099 occurred at Physical channel not specified.
Where am I going wrong?
Willem.
Message Edited by wv on 02-09-2006 11:22 AM
(3,202 Views)
Check that MAX is not configured to use the DAQmx driver instead of the DAQmx Base driver.  You can do this by opening max, Tools > NI-DAQmx Confgiuration > NI-DAQmx USB Driver Selection. If it says that it is using NI-DAQmx and your program is written for mx BASE, you will need to switch the drviers using the switch button.
Also, make sure that your program and the logger are looking for the device name that you have programed into the program, ie, under MAX it lists the device as Dev1 and your program is looking for Dev1.
Kenny
Kenny
(3,186 Views)
It works !
Thanks very much,
Willem.
(3,182 Views)
