Showing results forĀ
Search instead forĀ
Did you mean:Ā
formula node
I am sending it an area that the indicator shows as a full decimal but recieve and integer. I have changed the data types from  double to long to extended float etc without any results. Is there something I am doing wrong?
Message 1 of 9
(6,362 Views)
agator2 wrote:Is there something I am doing wrong?
Probably yes, If you post the code we'll take a look at it
"Should be" isn't "Is" -Jay
Message 2 of 9
(6,360 Views)
Top right corner contains the formula boxes. Excuse the mess of code surrounding.
Message 3 of 9
(6,357 Views)
Are you talking about inputs and outputs of a formula node?
  • Is the output terminal blue or orange?
  • Is the terminal of the indicator blue or orange?
  • What is the display format of the indicator?
Message 4 of 9
(6,351 Views)
Remove the word "int" at the beginning of each formula node line, remove the conversion bullet later, and change the representation of the indicator terminals to DBL (right-click..representation...DBL).
Message 5 of 9
(6,350 Views)
Accepted by topic author agator2
It could look like this, for example...
Message 6 of 9
(6,343 Views)
It says that I have undefined variables now
Message 7 of 9
(6,332 Views)
You need to create a terminal for "q" OR
r =sqrt(A/pi);
d = sqrt(A/pi)*2;
v = (4/3)*3.1415*r*r;
since q isn't used outside the node
Message 8 of 9
(6,328 Views)
thank you for the help
Message 9 of 9
(6,323 Views)
