format text file from internet
I need to format a text file data that is generated in VB and displayed in a webpage address (http://192.xxx.xxx.xx/data.txt). The data looks garbled right now and I need to make it appear in some readable form (tables, spreadsheet etc).  I dont have access to the VB file or the webserver that ports the data to Port 80.
 Is there a way to format this text file?
Any help is appreciated.
Thanks in advance.
kmoorthy
Message 1 of 8
(3,920 Views)
Why don't you attach a sample text file you we know what you are talking about. "Garbled" is not a very specific description. 😉
Message 2 of 8
(3,914 Views)
Hi Altenbach,
Please see attached file.  My intention is to make the data reader-friendly.  Thats what I mean by garbled.  The data makes sense now, but its just haphazard.
This is my approach to the issue and please correct me if I am doing it wrong... I am grabbing the data from the URL using Datasocket as a string and then using the string to array function to format it.  Then I intend to use the webserver and display the formatted data on a different URL.  Does this make sense or am I lost?
Message 3 of 8
(3,899 Views)
Oops.. Sorry I forgot the file.  Here u go...
Message 4 of 8
(3,897 Views)
A table seems fine. Here's one example (LabVIEw 7.1) to do this (assuming 23 columns). It is a little wide,so the table needs to be scrolled horizontally. You might want to only select a few interesting columns for display.
Let me know if anything is not clear. 🙂
Message 5 of 8
(3,884 Views)
Hi Altenbach.
Thanks for the response.  I am not sure where did the number 32 come from? I am trying to split the data in such a way that the header "date" has all the dates (7/21/05) in the following rows and the header "time" has its corresponding entries in the subsequent rows and so on..
KM
Message 6 of 8
(3,880 Views)
Well, the "32" was just a wild guess, you can choose any number you like until it looks right. (any other number does not quite look right to me, though)
You can take my example as a start, then slice out the interesting columns further and arrange or parse things anyway you want. I cannot know what you want! ;).
Message 7 of 8
(3,876 Views)
Thanks altenbach. It makes sense now.  I appreciate your help.
KM
Message 8 of 8
(3,869 Views)
