‎07-29-2013 10:12 AM
@gmazza wrote:
ehmmm???
Go to the File IO->Advanced File Functions palette. There is a Get File Extension.vi in there. One of the outputs is the file name without the extension.
‎07-30-2013 04:06 AM
I can not solve.
I repeat the problem: I have an array with an indefinite number of items. I want to eliminate the final part of each element.
Is there a way to do this?
‎07-30-2013 04:08 AM - edited ‎07-30-2013 04:08 AM
‎07-30-2013 04:27 AM
Sorry. I still do not understand how to do ...
Ok, I have to use a for loop. But I can not delete a portion of each array element.
‎07-30-2013 04:33 AM
‎07-30-2013 04:36 AM
Or if you want to use an available function, which strips the extension.
‎07-30-2013 04:37 AM
‎07-30-2013 04:58 AM
the problem is just to find a code to stripping the string...
‎07-30-2013 05:04 AM
Ok. Perfect. Frabto's solution works well and is very simple .. thank you
