fix column width using Append Table to Report.vi
Using the VI 'Append Table to Report.vi' I want to set a fix column width (the best would be to set the width of each column...). By wiring the input 'column width', the widths of the columns still depend on the amount of text of the single columns. Is there a way to solve my problem? Or does anybody know, what that input 'column width' really means?
(2,665 Views)
Hi!
You have to use propertynode of XL column.
See the attachment. See the block diagram you will get idea.
Jenilia D'souza
Canberra
Australia
Jenilia D'souza
(2,661 Views)
