fit a chart
hello
i d like to fit a chart is it possible please help me
vince
vince
Message 1 of 9
(4,188 Views)
Fit to what? Fit the data, fit to screen, fit to something else?
Message 2 of 9
(4,175 Views)
fit continuous graph data and when I push on the STOP buttton, I d like to fit this graph
vince
Message 3 of 9
(4,160 Views)
Hi
If you want to do some calculations for fitting to your data you shuold watch on Matehematics >> Fitting functions.
There is some fitting functions that could help you with your problem.
bogdani
Message 4 of 9
(4,152 Views)
Have a look at attached VI
Just use any relevant fit type form, functions>>analyze>>mathematics>>curve fitting tools
Message 5 of 9
(4,146 Views)
I know how to fit a graph but I have a chart so I fit only one point
vince
Message 6 of 9
(4,133 Views)
Hello wouince,
well, just collect the points you need and do the normal fitting (like it is done with your graph).
For collecting data a shift register holding an array of data can be used. Or you use the history property of your chart...
Message 7 of 9
(4,121 Views)
Or, if you are getting these points inside a loop, enable auto indexing at loop output and get an array of points
Message 8 of 9
(4,117 Views)
Thank you I used the historic and now It s OK
vince
Message 9 of 9
(4,106 Views)
