find txt in table
Hi all:
How can I know which row and column txt "Fail" exist in this table
thanks
(2,124 Views)
Just one solution... which will check every cell of the table and return all occurences.
Message Edité par JB le 10-27-2008 03:55 PM
(2,112 Views)
Hi Elyan,
If you know which column the Fail String is contained within, you can use the Index Array function to give you a 1-D array of Strings with the various status commands within. If you then use this 1-D array and use the "Search 1-D Array" to find any rows which are set to Fail. The attached image shows how to find the first Fail element.
Andrew McLennan
Applications Engineer
(2,107 Views)
