find the average of each 500 values in a column [text file]
please help, i hv a text file with three columns of integer values. I need to take 500 values in each column and replace them with their average.
Message 1 of 8
(2,891 Views)
All your posts are the same thing.  You provide a file and a task and then say "Please help" but you never actually show that you've at least tried to do your own work.
Post your attempt at this task an you'll get better assistance...
Message 2 of 8
(2,880 Views)
i did it
Message 3 of 8
(2,878 Views)
Congratulations! Smiley Happy  I'm still stuck with LabVIEW 2010 so I can't open your code.  Have you tested it?
Message 4 of 8
(2,871 Views)
Accepted by Mahisnair
A lof if this could probably be simplified. Here are some ideas.... Many thing could be improved even more.
Message 5 of 8
(2,848 Views)
@Niquist: i have only labview 2011 to use friend, the code is working.
Thanks for the reply
Message 6 of 8
(2,828 Views)
Message 7 of 8
(2,827 Views)
Message 8 of 8
(2,821 Views)
