find all sub vis that are set to show front panel when called
I have inherited a very large messy sphagetti code of about 1500 vis,
i need to refactor it to a maintainable state. one requirement is to give a make over on the front panel with a logo on all the subVIs that pop-up when called.
is there an easy way to list all vis that are set to "show front panel when called" property in the VI properties ctrl+i menu ?
(3,500 Views)
You can read that property with a property node. However there is more than one way to open a subVIs front panel.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,497 Views)
in your tools bar go to menu of view select view hierarchy
you can see all subvi right click on them and see property of them
(3,480 Views)
There are more than 300/1500 Vis that are pop-up,
i will have to try something programatic to list all automatically
(3,478 Views)
may be this code colud help you
but regard that this will be work if your subvi are save with this  property (set to show front panel when called)
and I do notthink it work for mode that you manully right click on subvi and selected as open FP when called
anyway I hope it could help you
(3,470 Views)
