05-24-2016 05:41 PM
I have inherited a very large messy sphagetti code of about 1500 vis,
i need to refactor it to a maintainable state. one requirement is to give a make over on the front panel with a logo on all the subVIs that pop-up when called.
is there an easy way to list all vis that are set to "show front panel when called" property in the VI properties ctrl+i menu ?
05-24-2016 05:48 PM
05-24-2016 07:35 PM
05-24-2016 07:39 PM
There are more than 300/1500 Vis that are pop-up,
i will have to try something programatic to list all automatically
05-24-2016 08:39 PM
may be this code colud help you
but regard that this will be work if your subvi are save with this property (set to show front panel when called)
and I do notthink it work for mode that you manully right click on subvi and selected as open FP when called
anyway I hope it could help you
