filter complex number
Is there a way to (bandpass) filter complex signals in Labview? I googled it but i do not seem to find a way to filter complex signals (a+i*b).
Edit: The normal bandpass filter block won't work because it does not accept complex input
(4,269 Views)
Accepted by valentina.alina
Split it into re/im, filter individually, recombine.
(4,260 Views)
I'm sorry if this is a dumb question but is it correct (mathematically) to do so?
(4,253 Views)
aaaand i have my answer: https://ccrma.stanford.edu/~Jos/filters/Real_Linear_Filtering_Complex.html  . In case someone has the same problem, folow the link.
Thank you, Sir for your time Smiley Very Happy
(4,249 Views)
The link has extra characters. Try this link.
Lynn
(4,236 Views)
Looks like the link changed again! Here's the new link:
https://ccrma.stanford.edu/~jos/fp/Real_Linear_Filtering_Complex.html
(3,930 Views)
