fill rectangle with a specified color
hello guys,
  i am plotting a rectangle, which represents the amount of force applied on force transducer.  It moves left or right depending on whether the force is applied or not.  using the force value at any particular time, i have written a code for generating a rectangle on XY graph.  How can i fill this rectangle with any color?  Thank you.
Dhruvit
Message 1 of 9
(4,640 Views)
Hi Druvit
Why do you want to use a graph and not just use one of this nice numerical indicators? For instance a tank?
This is filled with a color and you can easily assign a value.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 9
(4,635 Views)
You could also use a picture indicator instead. The attached VI shows two possibilities
Message 3 of 9
(4,625 Views)
Hi Thomas,
  I am using a graph because I want to leave the trace even if the rectangle, which i am using as a cursor, comes back to initial value.  i have attached a picture file for your reference.  thank you for your reply.
Dhruvit
Message 4 of 9
(4,610 Views)
Also, you can define your own control (with rectangle type).  Create a property node for this control. Last, just setup the property (color).
Message 5 of 9
(4,611 Views)
SImilar to your box, I have produced multi-colour hanging bar plots on an x-y chart by drawing the rectangle with 2 short plots, using property Plot.FillTo between them to add or change the colour using Plot.Color, and no interpolation.
To draw the box on an xy chart :
For the y axis, or  sides of the box create a 2 element array with upper and lower values - values duplicated,  and for the x axis another 2 element array with the top and bottom of the box in relation to the x origin.  Bundle each y array with the x array, then join together with build array - you get your cluster of arrays for multiple plots on the x-y chart.
This is a very flexible method that but the explanation above may be a bit complicated, if you would like an example vi, then I'll tidy up what I've got and post it. (Its very application specific at the moment);
Lucy
Message 6 of 9
(4,603 Views)
Hi lucy,
  can you send me your vi file.  i have labview 6, so if you have labview 7 then is it possible for you to save it as labview 6 compatible.  thanks for your help.  i am doing the same thing as you are.
Dhruvit.
Message 7 of 9
(4,591 Views)
I have attached the vi, but it is in LV7, Sorry I no longer have 6.1 installed. I'll post a picture of it if you can't get it converted.
Lucy
Message 8 of 9
(4,563 Views)
Here is Lucy's code as LV 6.0.
I only go back to LV 6.1 so I could not test this.
Ben
Message 9 of 9
(4,548 Views)
