fill a 1000 dimension array with data from serial port using VISA
Hi there, I'am trying to store data from serial port into an array of dimension 1000, which I want to plot afterwords but doesn't seem to work. After getting 1000 elements from serial I only have two in my array. What I want to do is append every one of the 1000 values to the same array, but it doesn't seem to work. What am I doing wrong?Capture.PNG
(3,201 Views)
Hi samo,
I never used LabVIEWNXG before but I guess from your image you are building an array of 2 elements (displayed in "output array") in your loop. You create that array in each iteration and after the last iteration that 2-element array is output from the loop.
Does NXG support shift registers? Why don't you use them?
(3,198 Views)
Or have the output tunnel be autoindexing.  Also, your loop should be a FOR loop since you know beforehand how many times it should iterate.
Your use of "dimension" is completely wrong.  You are trying to create a 2 dimensional (2D) array with 1000 rows.
(3,170 Views)
Thanks for info, but can you be a little bit more specific?
I' am  relative new to LabVIEW especially NXG.
(3,142 Views)
Hi samo,
What about that "Training" section in the header of this LabVIEW board, dedicated to LabVIEW beginners?
All our suggestions are VERY basic stuff…
(3,138 Views)
@crossrulz wrote:
Your use of "dimension" is completely wrong.  ...
That is what brought me into this thread. I once created a 100-D array just to see if I could break LV. You can imagine what the wire looked like! But then actually putting data in that wire... Out of memory.
Ben
(3,122 Views)
