file row number
Hi :
I have txt file the include data into it
I want to know the number of row inside this file
how I can do that using labview
thanks alot for your help
I have attach file for example if  you can see the this file have 7 rows
(2,993 Views)
Accepted by topic author Elyan_wisam
You can use the read text file primitive from file file palette, and then right clic on it to select "read rows" :
Then it slightly changes the icon and the function :
Hope this helps
Epictetus
Antoine Chalons
(2,986 Views)
Be careful with this solution.  It can easily result in a memory issue, since you are reading the whole file.
If this is a problem, read the file in 65,000 character blocks and search each block for EOL (end of line) characters.  Be aware that EOL varies from platform to platform, and can be \r, \n, or \r\n.  This is usually only a problem when moving files from one OS to another.  The End of Line constant in LabVIEW gives you the proper EOL for the platform under which it is running.  If properly implemented, this method is faster than the previous one.
(2,969 Views)
